additude
Apr 01, 2020Virtuoso
Log on RAX120 incomplete entries
My RAX120 just locked up for no apparent reason last night sometime. The last indication that I have was that around 8PM last night it was still working, I received an email from my security system. ...
Newfiedrool
Apr 02, 2020Virtuoso
Yes, when you reboot the router all logs previous to the reboot are gone.
if you can't access the router via WiFi then the next option is via a wired connection if you need to look at the logs when a routers WiFi fails to show or you can't connect.
additude
Thanks....
