RouterBeast22
Nov 28, 2022Aspirant
Looking for compatible USB Storage for RAX43 WiFi Router
I just purchased a AX5 RAX43 WiFi Router. I would like to know what USB storage devices are compatible?
michaelkenward
Nov 29, 2022Guru - Experienced User
As the manual for your router says, you can get an idea of what you can use from this page:
Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
If your device isn't there, check something similar for possibilities. A drive that shows up in different places might be a good bet.
Those lists are incomplete and out of date. There are just too many options out there for anyone to be able to maintain a comprehensive database.
