ddngusr
May 12, 2021Aspirant
Looking to extend router signal
Is there plugin way to extend this router's capabilities to the other side of the house to add an antenna? Looking for easiest way to configure.
ddngusr
- plemansMay 12, 2021Guru - Experienced User
Not sure what you mean by add an antenna.
Powerline devices do work. For some they work great.
For other's, its a struggle. Many things can impact powerline devices so some homes can be problematic.
Usually you have to try to find out.
You can also check into extenders as well. I'm a fan of the triband line of extenders because of their dedicated backhaul
