Londonsmee
Mar 20, 2023Aspirant
Losing DNS on ethernet
Keeps losing DNS with latest firmware, rolling back to RAX200-V1.0.5.132_1.0.69. Have done a factory reset and still had the issues. Please fix the firmware, for I do like my nighthawk.
Londonsmee
2 computer that are connected via ethernet wont find the internet, they connect to the router but no dns. Router sees them connected. Meanwhile phones seen on wifi can access web.
A full reset gets the ports working but then becomes intermittent on the ethernet. In the past been fine.
Mar 20, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
