usafmary
Nov 17, 2024Aspirant
Losing the wi-fi randomly
I have an RAX50 router purchased in 2021. We have 2 PCs that randomly lose the wi-fi and at different times. When PC1 is affected, I can't ping the router and PC2 can't ping PC1. The router also r...
Kitsap
Nov 17, 2024Master
usafmary wrote:I have an RAX50 router purchased in 2021. We have 2 PCs that randomly lose the wi-fi and at different times. When PC1 is affected, I can't ping the router and PC2 can't ping PC1. The router also refuses connection to PC1 when I try to sign into the router.
I've tried so many things:
- made sure firmware was up-to-date;
- tried different drivers;
- rebooted modem, router and PCs;
- deleted/recreated adapters;
- etc., etc.
I have a smart TV and Roku and cell phone that don't lose connection though they're probably not used as often as the PCs.
I've read that routers should last 3-5 years so, is it time to get a new one or does anyone have a suggestion that I may not have tried?
Thank you in advance,
-mary
Do you allow either of the PC's to go into power save (sleep) mode? If yes, check the PC settings to see if the adapters are also allowed to go to sleep. Some adapters are better than others in restoring a connection after coming out of sleep mode.
usafmary
They both go into sleep mode but sleep on the adapters isn't allowed. Thank you for your suggestion though.
