BBQDave
Oct 22, 2020Guide
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
RAX40 AX3000 Wi-Fi 6 Firmware Version: v1.0.3.80_1.0.1 (most current) Enable AX and Enable Smart connect are both off because of issues with the PC I'm using has an older modem internally (at least...
- Nov 05, 2020
I hope it helps others. I tossed my Netgear router and purchased a Linksys Dual-Band WiFi 6 Router model AX1800 three days ago. Works perfect! No drops and is super fast. I highly recommend it and suggest anyone to toss their Netgear products.
Oct 22, 2020Guru - Experienced User
What modem do you have?
Since the update to the firmware you're on, have you tried a factory reset on the router?
And then reinstalling it not using a backup? This can help with the RAX devices since they got such significant firmware changes.
If that doesn't help, you can try downgrading the firmware a version. Maybe the one you're on has a bug.
BBQDave
Oct 22, 2020Guide
I did not do a factory reset after the firmware update.
The modem is supplied by Spectrum and doesn't have a model name on it.
I've only had this router for about 4 months and initially I wasn't having this issue, but after about a month, this started happening. When the issue started, it dropped out maybe once a week or so, but now it's a couple times a day. To fix it, I turn off my modem and turn off my router, and re-start both.
I will add that this issue was happening prior to me updating the firmware on the router and I read that I should try using the most current firmware version if I'm having issues, and yet the same issue persists.
If I do a factory reset, will I have to change all my device settings that are connected to this router? I only have like 20 but that would be a pain if it doesn't fix this issue.
- itsmehueyOct 22, 2020LuminaryIf you read all of the posts regarding wifi drops that everyone is having your know this is occurring mostly with the .80 firmware and the only workaround at the moment is to downgrade back to .64 firmware until Netgear finally release a fixed firmware to replace V .80. Beta has been tested for quite some time so I don’t understand what’s taking them so long.
- BBQDaveOct 26, 2020Guide
So here's the latest.
I downloaded an app on my phone called "WiFi Analyzer". It will show you which channels have the best connection and least interference for your router and location. I changed the channels for both my 2.4 GHz and 5 GHz connections back on Thursday afternoon to one's that were shown to give the best signal. I have not had a dropped signal since, compared to a couple times a day for the last month. I'm not a real techy, and everything I went through would probably be way too confusing for the average person, so I certainly hope Netgear fixes whatever they need to fix in a firmware update, otherwise these types of routers will be a couple hundred-dollar pieces of junk.
- BBQDaveOct 29, 2020Guide
Well, I spoke too soon. At least it's now only dropping out once every 3 days. Happened the evening of the 26th and this afternoon again. There's obviously some major issue with this firmware. Looks like this model is a boat anchor. If you have the chance to read through all of these posts, you should know not to buy this model; and it may be best to not buy Netgear products. Go for LinkSys.
