BBQDave
Oct 22, 2020Guide
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
RAX40 AX3000 Wi-Fi 6 Firmware Version: v1.0.3.80_1.0.1 (most current) Enable AX and Enable Smart connect are both off because of issues with the PC I'm using has an older modem internally (at least...
- Nov 05, 2020
I hope it helps others. I tossed my Netgear router and purchased a Linksys Dual-Band WiFi 6 Router model AX1800 three days ago. Works perfect! No drops and is super fast. I highly recommend it and suggest anyone to toss their Netgear products.
BBQDave
Oct 22, 2020Guide
I did not do a factory reset after the firmware update.
The modem is supplied by Spectrum and doesn't have a model name on it.
I've only had this router for about 4 months and initially I wasn't having this issue, but after about a month, this started happening. When the issue started, it dropped out maybe once a week or so, but now it's a couple times a day. To fix it, I turn off my modem and turn off my router, and re-start both.
I will add that this issue was happening prior to me updating the firmware on the router and I read that I should try using the most current firmware version if I'm having issues, and yet the same issue persists.
If I do a factory reset, will I have to change all my device settings that are connected to this router? I only have like 20 but that would be a pain if it doesn't fix this issue.
itsmehuey
Oct 22, 2020Luminary
If you read all of the posts regarding wifi drops that everyone is having your know this is occurring mostly with the .80 firmware and the only workaround at the moment is to downgrade back to .64 firmware until Netgear finally release a fixed firmware to replace V .80. Beta has been tested for quite some time so I don’t understand what’s taking them so long.
