BBQDave
Oct 22, 2020Guide
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
RAX40 AX3000 Wi-Fi 6 Firmware Version: v1.0.3.80_1.0.1 (most current) Enable AX and Enable Smart connect are both off because of issues with the PC I'm using has an older modem internally (at least...
- Nov 05, 2020
I hope it helps others. I tossed my Netgear router and purchased a Linksys Dual-Band WiFi 6 Router model AX1800 three days ago. Works perfect! No drops and is super fast. I highly recommend it and suggest anyone to toss their Netgear products.
BBQDave
Oct 26, 2020Guide
So here's the latest.
I downloaded an app on my phone called "WiFi Analyzer". It will show you which channels have the best connection and least interference for your router and location. I changed the channels for both my 2.4 GHz and 5 GHz connections back on Thursday afternoon to one's that were shown to give the best signal. I have not had a dropped signal since, compared to a couple times a day for the last month. I'm not a real techy, and everything I went through would probably be way too confusing for the average person, so I certainly hope Netgear fixes whatever they need to fix in a firmware update, otherwise these types of routers will be a couple hundred-dollar pieces of junk.
BBQDave
Oct 29, 2020Guide
Well, I spoke too soon. At least it's now only dropping out once every 3 days. Happened the evening of the 26th and this afternoon again. There's obviously some major issue with this firmware. Looks like this model is a boat anchor. If you have the chance to read through all of these posts, you should know not to buy this model; and it may be best to not buy Netgear products. Go for LinkSys.
- itsmehueyNov 05, 2020Luminary
OK after weeks and numerous follow ups to my L2 support representative, they finally have another beta for me to test.. RAX40-V1.0.3.83_1.0.10 dated 4th November 2020
I'll be testing and monitoring over the course of the week and will report back my findings and experience with the update.- BBQDaveNov 05, 2020Guide
- BBQDaveNov 09, 2020Guide
It's been a week and no drops! Linksys is the way to go.
- melnictumNov 11, 2020Aspirant
I have had this same exact problem for over a month now! Hooray! You are the first person I've found with the same experience albeit your device is slightly different. I've tried EVERYTHING: reboot, restore, download previous version of software, download latest version of software, adjust every channel, frequency, ax on/off, etc., and nothing works. The worst part is, I'm only running a macbook pro, firestick, kindle and two iphones on this router and it's either ridiculously slow or it's constantly dropping the signal every few minutes and reconnecting. I have had the Dos attacks and syn flood logs showing up with some questionable ip addresses too, but I think they're probably bogus.
How did you get a support rep to give you a beta firmware trial? I bought my router the end of May and it worked great until September. I don't want to pay for a support plan and I'm hoping I don't have to buy another router b/c this one was specifically recommended by the nerds at Best Buy. Support team, will you help me please?
It's worth a try. :) Thanks in advance.
- itsmehueyNov 11, 2020Luminary
melnictum wrote:How did you get a support rep to give you a beta firmware trial? I bought my router the end of May and it worked great until September. I don't want to pay for a support plan and I'm hoping I don't have to buy another router b/c this one was specifically recommended by the nerds at Best Buy. Support team, will you help me please?
create a support case. if no one provides you with anything, escalate to a moderator here (e.g. Christian_R)
