BBQDave
Oct 22, 2020Guide
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
RAX40 AX3000 Wi-Fi 6 Firmware Version: v1.0.3.80_1.0.1 (most current) Enable AX and Enable Smart connect are both off because of issues with the PC I'm using has an older modem internally (at least...
- Nov 05, 2020
I hope it helps others. I tossed my Netgear router and purchased a Linksys Dual-Band WiFi 6 Router model AX1800 three days ago. Works perfect! No drops and is super fast. I highly recommend it and suggest anyone to toss their Netgear products.
jiberesh
Nov 16, 2020Guide
Im in the same boat with you. wifi keeps dropping. changed channels, turned off same settings. Still dropping. Did you ever get access to the beta software? Im tired of having the wifi drop while im in class or taking a test. My sisters are complaining at me nonstop. i dont want to buy the support thatll only last 6 months.
itsmehuey
Nov 18, 2020Luminary
jiberesh wrote:Im in the same boat with you. wifi keeps dropping. changed channels, turned off same settings. Still dropping. Did you ever get access to the beta software? Im tired of having the wifi drop while im in class or taking a test. My sisters are complaining at me nonstop. i dont want to buy the support thatll only last 6 months.
keep pestering the support guys until you get some help and assistance to obtain the beta. i've already given the engineering team my feedback saying that the latest beta is rock solid so i dont understand why it's taking them so long to release a public update.
- jibereshNov 18, 2020GuideHow long do I have to pester them for? It’s been a week of contact and no sign of improvement. I just want the WiFi to not drop mid class.
