BBQDave
Oct 22, 2020Guide
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
RAX40 AX3000 Wi-Fi 6 Firmware Version: v1.0.3.80_1.0.1 (most current) Enable AX and Enable Smart connect are both off because of issues with the PC I'm using has an older modem internally (at least...
- Nov 05, 2020
I hope it helps others. I tossed my Netgear router and purchased a Linksys Dual-Band WiFi 6 Router model AX1800 three days ago. Works perfect! No drops and is super fast. I highly recommend it and suggest anyone to toss their Netgear products.
MightyMouse2099
Nov 18, 2020Tutor
I have the same issue with mine and even replaced it with a refurbished from netgear support with same issue. This is truly a real issue. Support won't help you either and wait until warranty is up to toss you to the curb.
- jibereshNov 18, 2020GuideI’m not paying 90$ for a problem that shouldn’t be there. That’s absurd.
- MightyMouse2099Nov 18, 2020Tutor
You are absolutely correct, Netgear needs to wake up on this one!
- itsmehueyNov 18, 2020Luminary
yeah it's been a frustrating time with this router to say the least. I know some of us were lucky enough to get through to support by constant follow ups, pestering forum mods, going onto social media and so forth.. so just keep at it. I was able to get through to escalation @ L2 support by sending a PM to Christian_R who helped me get in contact with them.
The current beta is stable, so there is no reason why they would hold out any longer to release a public version.
jiberesh wrote:
I’m not paying 90$ for a problem that shouldn’t be there. That’s absurd.they really need to review this outright sham of a scam.. we've purchased a product with 12 months warranty. technical support SHOULD be included as part of this warranty.
- jibereshNov 19, 2020Guide
Im just buying a asus router. This is annoying.
