BBQDave
Oct 22, 2020Guide
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
RAX40 AX3000 Wi-Fi 6 Firmware Version: v1.0.3.80_1.0.1 (most current) Enable AX and Enable Smart connect are both off because of issues with the PC I'm using has an older modem internally (at least...
- Nov 05, 2020
I hope it helps others. I tossed my Netgear router and purchased a Linksys Dual-Band WiFi 6 Router model AX1800 three days ago. Works perfect! No drops and is super fast. I highly recommend it and suggest anyone to toss their Netgear products.
itsmehuey
Nov 18, 2020Luminary
jiberesh wrote:
I’m not paying 90$ for a problem that shouldn’t be there. That’s absurd.
they really need to review this outright sham of a scam.. we've purchased a product with 12 months warranty. technical support SHOULD be included as part of this warranty.
jiberesh
Nov 19, 2020Guide
Im just buying a asus router. This is annoying.
