BBQDave
Oct 22, 2020Guide
Losing WiFi connection on RAX40 AX3000 Wi-Fi 6
RAX40 AX3000 Wi-Fi 6 Firmware Version: v1.0.3.80_1.0.1 (most current) Enable AX and Enable Smart connect are both off because of issues with the PC I'm using has an older modem internally (at least...
- Nov 05, 2020
I hope it helps others. I tossed my Netgear router and purchased a Linksys Dual-Band WiFi 6 Router model AX1800 three days ago. Works perfect! No drops and is super fast. I highly recommend it and suggest anyone to toss their Netgear products.
JCSooner
Nov 23, 2020Tutor
i don't think there is a solution, only temperary solutions that only fail later. I replaced mind as it was glitchy from day one, then had a major DHCP failure, which is more than likely what you are experiencing. if you have devices with fixed ip addresses, it will probably work fine, but I had pretty much the same issues. No WiFi, but it said it was working, static hardwire PC's worked fine, but not any dhcp pc's. wifi wouldn't transmit. it was a mess. Give it up and stop wasting your time being a beta-tester for NG. Just buy a more reliable router. Good Luck!
