LosingMyWiFi25
May 15, 2022Aspirant
Losing WiFi Signal RAX48
My RAX48 is connect directly to my modem. WiFi works great and all 29 of my wireless devices connect. As soon as I plug my Netgear unmanaged switch into the RAX48, the WiFi network stops working. Once I unplug the switch and reboot the router and modem, WiFi works fine. Only loses WiFi when Ethernet ports are used on wireless router. Help please!
what switch is it?
- LosingMyWiFi25AspirantNetgear ProSafe Gigabit GS108NA. It’s an older model. Will a newer version provide better results?
it really shouldn't matter. that switch is a pretty basic one and it shouldn't cause an issue.
Did you try different cables or different ports on the router/switch?
Is the router new?
