justinto
Nov 14, 2020Aspirant
Losing Wired Connections
A few times a week, the router loses the wired lan connections (R9000 X10 AD 7200) but the wireless connections stay on. This is annoying and I cannot find out why. I have read some of the other comp...
Nov 14, 2020Guru - Experienced User
After the reset, try a clean install and not from backup. If there's an issue with an old setting causing issues, restoring the saved configuration just puts the bad setting back in there.
- justintoDec 03, 2020Aspirant
Thank you for your reply. Interestingly, I have not had the issue since I posted. I will try your suggestion if this happens again. Stay healthy.
