justinto
Nov 14, 2020Aspirant
Losing Wired Connections
A few times a week, the router loses the wired lan connections (R9000 X10 AD 7200) but the wireless connections stay on. This is annoying and I cannot find out why. I have read some of the other comp...
roger1955
Nov 14, 2020Apprentice
Hi,
I to had that issue, where the LAN would disconnect and then reconnect. Pleman's suggestion is spot on. I haven't had any issues since I did a factory reset, followed by a clean install. BTW, my X10 was dropping the LAN while in Router mode. After I purchased the RAX200 and put the X10 in AP mode it still dropped LAN connection. That is not the case now, hasn't happen in several months. Good luck.
