justinto
Nov 14, 2020Aspirant
Losing Wired Connections
A few times a week, the router loses the wired lan connections (R9000 X10 AD 7200) but the wireless connections stay on. This is annoying and I cannot find out why. I have read some of the other comp...
Nov 14, 2020Guru - Experienced User
After the reset, try a clean install and not from backup. If there's an issue with an old setting causing issues, restoring the saved configuration just puts the bad setting back in there.
justinto
Dec 03, 2020Aspirant
Thank you for your reply. Interestingly, I have not had the issue since I posted. I will try your suggestion if this happens again. Stay healthy.
