tallen234
Feb 15, 2021Aspirant
Lost 5G Wireless Network
I bought the RAX45 about a week ago. Updated to the newest firmware. Set up the nework and everything was working fine, until last night. My 5G wireless network disappeared. I reset the modem and it didn't work. It just did a factory reset with no luck. The 5G light is off on the router. However, the 5G network appears in the GUI. I changed the channel for the 5G network multiple times with no luck. Any ideas?
Thanks
- tallen234Aspirant
I noticed tonight in the advanced settings that it says the 5ghz network is set on Channel 0. However, in the basic page it says it is on Channel 40. Strange. Could this be a problem with the radio? I bought this at Costco, so I can swap it out pretty easily.
- Christian_RNETGEAR Employee Retired
Hello tallen234,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
