Asielcode7
Jun 12, 2019Tutor
Lots of problems with RAX120
So I setup the this router 2 days ago and it's not playing nice with half of my devices so far. Many could not see the routers signal at all. I updated the drivers on devices that I could such as my P...
- Jun 12, 2019Disable AX mode, and/or update to the latest firmware and you shouldn’t have any issues even with AX enabled. Since most people don’t have any AX devices, turning that feature off will be fine.
Also make sure 2.4 GHz is in 20 MHz mode by selecting one option lower in WiFi speed selection in router WiGi settings or by making sure 20/40 switching is enabled. 40 MHz can be terrible in congested environments.
avtella
Jun 12, 2019Prodigy
Asielcode7
Jun 12, 2019Tutor
Isn't AX mode the whole point of owning this router? I also can't find out how to turn it off or any of the other modes you just described.
- Asielcode7Jun 12, 2019TutorSorry wrong model number, it is the AX6000
- avtellaJun 12, 2019ProdigyI haven’t issues like yours on either model. I have ax WiFi cards in all my laptops and a also a lot of non ax devices. However since you have issues I said to disable AX mode.
Unless you have ax devices ax mode won’t have any effect anyway. The option is in the router’s WiFi settings page under the “Basic” tab. In that same page you will see a connection speed selection for 2.4 and 5 GHz. On the 2.4 Ghz select on step lower than current after disabling ax mode.- avtellaJun 12, 2019Prodigy
Hopefully in the meantime some of the compatibility issues are resolved client side as well as router side in upcoming updates.
FYI both the RAX80 and RAX120 are AX6000 devices. AX6000 is just the sum of the 2.4Ghz and 5Ghz peak theoretical bandwidths combined.
- michaelkenwardJun 13, 2019Guru - Experienced User
Asielcode7 wrote:
Sorry wrong model number, it is the AX6000That's a wifi speed designation.
The model number is probably RAX120, RAX80, or something similar.
Look on the label on the thing.
