Asielcode7
Jun 12, 2019Tutor
Lots of problems with RAX120
So I setup the this router 2 days ago and it's not playing nice with half of my devices so far. Many could not see the routers signal at all. I updated the drivers on devices that I could such as my P...
- Jun 12, 2019Disable AX mode, and/or update to the latest firmware and you shouldn’t have any issues even with AX enabled. Since most people don’t have any AX devices, turning that feature off will be fine.
Also make sure 2.4 GHz is in 20 MHz mode by selecting one option lower in WiFi speed selection in router WiGi settings or by making sure 20/40 switching is enabled. 40 MHz can be terrible in congested environments.
schumaku
Jun 12, 2019Guru - Experienced User
Asielcode7 wrote:
I updated the drivers on devices that I could such as my PC's and laptops (8 total) and that worked for most of them, 2 of my laptops still can't see the wifi signal from it.
In case these are Windows systems with Intel Wi-Fi, head to the Intel Driver Support Assistant - note the vendor updates for many systems are lacking, as well as the Microsoft distributed drivers.
In case these are other Wi-Fi clients, provide details like make, model, driver versions, ...
