Asielcode7's avatar
Jun 12, 2019
Lots of problems with RAX120
So I setup the this router 2 days ago and it's not playing nice with half of my devices so far. Many could not see the routers signal at all. I updated the drivers on devices that I could such as my P...
  • avtella's avatar
    Jun 12, 2019
    Disable AX mode, and/or update to the latest firmware and you shouldn’t have any issues even with AX enabled. Since most people don’t have any AX devices, turning that feature off will be fine.
    Also make sure 2.4 GHz is in 20 MHz mode by selecting one option lower in WiFi speed selection in router WiGi settings or by making sure 20/40 switching is enabled. 40 MHz can be terrible in congested environments.
