StarPilot's avatar
StarPilot
Follower
Feb 27, 2021
lousy wifi AX1800 Wifi 6 router
i replaced my old Linksys with this newer Netgear.  I get less reception. the 5ghz only works if you are next to the router.  The 2.4ghz is weak in two rooms away.  My Linksys was stronger that this ...
