Mdbradsh
Feb 27, 2023Apprentice
Low LAN and 5GHz WIFI speeds from RAXE500 Router?
Hello! I have a CM2000 modem that is supplying 1400+mps to a RAXE500 router. However, my wired LAN connection from the router to my 3 year old HP laptop tops out at 400-500mps? And my iPhone 12 ...
Kitsap
Mar 02, 2023Master
Mdbradsh wrote:I have tried it with modem to 2.5 gig Ethernet port and PC connected to the "regular" 1 gig Ethernet port, and PC also connected to each of the LAN ports 1 - 4, with no change in 400-500 mps speed no matter the choice. And Link aggregation turned off
There may be two places to turn link aggregation off. One on the WAN side and one on the LAN side.
Mdbradsh
Mar 03, 2023Apprentice
Nothing for Link Agg. under LAN or WAN, in the RAXE500 Link Agg setting is only under Ethernet Settings. I checked and it's disabled, ....it's disabled by default.
