rafaelfclima
Sep 29, 2021Aspirant
Low speeds for my brand new modem
Just bought htis router/modem and am getting just 180 Mbps WIRED direct ot the unit... I have 1.2 Mbps plan with Xfinity... Already spent several hours with the internet service provider on the phone...
Sep 29, 2021Guru - Experienced User
Did they ever re-provision it for you? I've seen them send the wrong provisioning file before.
How are you testing speeds?
rafaelfclima
yes they did. my laptop is directly wired to the modem. I am testing using xfinity's speed meter and also used ookla. Same results. Very few devices are connected to this modem.
- FURRYe38Sep 29, 2021Guru - Experienced User
What are your speed results with your wired PC connected to the modem after configuring modem mode only? Look for Router mode and set to NO. The modem will reboot.
Please post a copy and paste of the modems connection status page.
- rafaelfclimaSep 29, 2021Aspirant
where do I ghet this info?
is it you need?
Sorry, Im not an expert. What would be the consequences turning the router mode off?
