akhan999
Sep 28, 2023Aspirant
LTE backup for NETGEAR Nighthawk 12-Stream WiFi 6E Router (RAXE500)
Hi All, Hope you can help. I want to understand how I can get a backup LTE option with this router, if anyone has done this before and if so are there any instructions? Would appreciate any exp...
- Sep 28, 2023
Good Luck.
Sep 28, 2023Guru - Experienced User
The RAXE doesn't support any failover features. Something you'll need to look into a fail over router that has that support.
