architectscott
Oct 22, 2024Aspirant
MacOS 15.0.1 update causes issues with router
I have a Netgear 4-Stream AX1800 WiFi Router. I upgraded my MacBook today to 15.0.1 - and when it attempted to connect to the network after the upgrade, it was blocked which is really odd. So I do ...
Oct 23, 2024Guru - Experienced User
If the device was working along with the router before your device was updated, then we can presume your device would be the issue. Not the router.
Only apple device you have? Try a different apple device to compare?
What browser are you using? Safari? Try a different browser? Firefox or Opera do same thing?
Be sure to clear out any browser caches before trying to enter into the routers web page?
