JTBoo
Feb 08, 2020Follower
Making Router use 5GHz Band for Gaming
Have a Play Station 4 (PS4). Modem and Router Info listed above. Using the Nighthawk mobile app (version 2.4.18.7) for WiFi management, I have selected "smart connect" to more efficiently manage co...
michaelkenward
Feb 09, 2020Guru - Experienced User
It is down to the wifi client to make the connection. The router just puffs out wifi. Your PS4, or whatever you are using, then makes the link.
JTBoo wrote:
PROBLEM: The management app will only connesct the PS4 at 2.4GHz!
Obviously, this is inadequate and causes significant quality issues with interface.
What management app are we talking about here?
