JTBoo
Feb 08, 2020Follower
Making Router use 5GHz Band for Gaming
Have a Play Station 4 (PS4). Modem and Router Info listed above. Using the Nighthawk mobile app (version 2.4.18.7) for WiFi management, I have selected "smart connect" to more efficiently manage co...
Othgood
Feb 11, 2020Tutor
If you have an older PS4 is only supports 802.11 b/g/n, so that's where you'll stay.
If you have a Pro :
Go to Settings > Network > Setup Internet Connection > Use Wi-Fi > Easy.
Next press the Options button > select Wi-Fi Frequency Bands.
Select 5 GHz Only if listed and press X. 5 GHz frequency band is supported for PS4™ Slim and PS4™ Pro models.
Hope this helps you out.
