jackylee0908
Jun 15, 2022Aspirant
Many DoS attack events in log (RAX80)
Hi,
I got sometimes the internet couldn't access so I tried to check RAX80 log but also sometimes I could not able to see the login page, but finally I could login to the RAX80 and saw below logs, seems that the issue was caused by DoS attack, but I'm not sure, so I need your help to check below logs, to see which ones might be the root caused and how I can prevent it again(internet can't access issue), thanks.
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Thursday, Jun 16,2022 07:28:01
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Thursday, Jun 16,2022 07:27:51
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 07:19:50
[DoS attack: RST Scan] from source 143.255.131.193,port 642 Thursday, Jun 16,2022 07:05:56
[LAN access from remote] from 193.233.191.181 port 52803 to 192.168.1.5 port 5000 Thursday, Jun 16,2022 06:52:50
[DoS attack: RST Scan] from source 143.255.128.204,port 376 Thursday, Jun 16,2022 06:41:50
[DoS attack: snmpQueryDrop] from source 162.142.125.135,port 13554 Thursday, Jun 16,2022 06:37:28
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 06:28:17
[DoS attack: snmpQueryDrop] from source 147.203.255.20,port 36857 Thursday, Jun 16,2022 06:14:51
[LAN access from remote] from 103.151.122.22 port 47599 to 192.168.1.5 port 5000 Thursday, Jun 16,2022 05:36:13
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 05:31:47
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 05:30:03
[DoS attack: snmpQueryDrop] from source 198.199.106.214,port 40103 Thursday, Jun 16,2022 05:23:52
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 05:13:42
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 05:12:06
[DoS attack: snmpQueryDrop] from source 107.152.217.162,port 12131 Thursday, Jun 16,2022 05:00:09
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 04:55:29
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 04:55:16
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 04:55:13
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 04:31:47
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 04:30:03
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 04:25:20
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 04:24:15
[DoS attack: TCP SYN Flood] from source 89.248.163.187,port 43947 Thursday, Jun 16,2022 04:13:33
[DoS attack: TCP SYN Flood] from source 89.248.163.187,port 43947 Thursday, Jun 16,2022 04:13:23
[DoS attack: TCP SYN Flood] from source 89.248.163.187,port 43947 Thursday, Jun 16,2022 04:13:13
[DoS attack: TCP SYN Flood] from source 89.248.163.187,port 43947 Thursday, Jun 16,2022 04:13:03
[DoS attack: TCP SYN Flood] from source 89.248.163.187,port 43947 Thursday, Jun 16,2022 04:12:44
[DoS attack: TCP SYN Flood] from source 89.248.163.187,port 43947 Thursday, Jun 16,2022 04:12:32
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 03:31:47
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 03:26:33
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 03:25:43
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 03:24:15
[LAN access from remote] from 80.82.77.144 port 44986 to 192.168.1.5 port 5000 Thursday, Jun 16,2022 03:04:19
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 02:31:46
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 02:07:30
[DoS attack: snmpQueryDrop] from source 198.235.24.18,port 54486 Thursday, Jun 16,2022 01:59:52
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 01:31:46
[DoS attack: snmpQueryDrop] from source 147.203.255.20,port 57211 Thursday, Jun 16,2022 01:23:17
[DoS attack: snmpQueryDrop] from source 91.134.185.90,port 20575 Thursday, Jun 16,2022 01:02:32
[LAN access from remote] from 94.102.61.47 port 38945 to 192.168.1.5 port 5000 Thursday, Jun 16,2022 00:42:53
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 00:31:46
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Thursday, Jun 16,2022 00:20:05
[DoS attack: snmpQueryDrop] from source 185.94.111.1,port 52973 Thursday, Jun 16,2022 00:19:34
[LAN access from remote] from 89.248.163.213 port 40981 to 192.168.1.5 port 5000 Wednesday, Jun 15,2022 23:43:42
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Wednesday, Jun 15,2022 23:43:26
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Wednesday, Jun 15,2022 23:43:10
[DoS attack: snmpQueryDrop] from source 92.118.161.53,port 60858 Wednesday, Jun 15,2022 23:36:29
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Wednesday, Jun 15,2022 23:31:46
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:49:49
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:49:39
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:49:29
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:49:19
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:49:09
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:48:59
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:48:49
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:48:39
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:48:29
[DoS attack: TCP SYN Flood] from source 89.248.165.103,port 44497 Wednesday, Jun 15,2022 22:48:19
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:38:56
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:38:42
[DoS attack: ACK Scan] from source 31.13.87.34,port 443 Wednesday, Jun 15,2022 22:33:03
[DoS attack: ACK Scan] from source 104.115.249.249,port 443 Wednesday, Jun 15,2022 22:30:33
[DoS attack: ACK Scan] from source 104.22.55.126,port 443 Wednesday, Jun 15,2022 22:29:58
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:29:17
[DoS attack: ACK Scan] from source 104.115.249.249,port 443 Wednesday, Jun 15,2022 22:28:12
[DoS attack: ACK Scan] from source 142.251.43.14,port 443 Wednesday, Jun 15,2022 22:27:56
[DoS attack: ACK Scan] from source 35.201.105.49,port 443 Wednesday, Jun 15,2022 22:27:29
[DoS attack: ACK Scan] from source 34.96.74.134,port 443 Wednesday, Jun 15,2022 22:27:24
[DoS attack: ACK Scan] from source 23.96.112.38,port 443 Wednesday, Jun 15,2022 22:27:17
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:25:55
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Wednesday, Jun 15,2022 22:25:54
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:25:54
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Wednesday, Jun 15,2022 22:25:53
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:25:53
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Wednesday, Jun 15,2022 22:25:46
[DoS attack: ACK Scan] from source 20.198.162.76,port 443 Wednesday, Jun 15,2022 22:25:45
[DoS attack: NetBiosReplyDrop] from source 192.168.1.11,port 137 Wednesday, Jun 15,2022 22:25:45
[DoS attack: ACK Scan] from source 170.114.15.26,port 443 Wednesday, Jun 15,2022 22:25:44
[DoS attack: ACK Scan] from source 20.198.162.76,port 443 Wednesday, Jun 15,2022 22:25:44
[DoS attack: ACK Scan] from source 170.114.15.26,port 443 Wednesday, Jun 15,2022 22:25:43
[DoS attack: ACK Scan] from source 20.115.3.214,port 443 Wednesday, Jun 15,2022 22:25:40
[DoS attack: ACK Scan] from source 172.217.160.78,port 443 Wednesday, Jun 15,2022 22:25:29
[DoS attack: ACK Scan] from source 13.35.7.2,port 80 Wednesday, Jun 15,2022 22:25:28
[DoS attack: ACK Scan] from source 13.35.7.2,port 443 Wednesday, Jun 15,2022 22:25:28
[DoS attack: ACK Scan] from source 13.35.24.89,port 443 Wednesday, Jun 15,2022 22:25:28
[DoS attack: ACK Scan] from source 13.35.7.2,port 80 Wednesday, Jun 15,2022 22:25:27
[DoS attack: ACK Scan] from source 13.35.24.89,port 443 Wednesday, Jun 15,2022 22:25:27
[DoS attack: ACK Scan] from source 13.35.7.2,port 443 Wednesday, Jun 15,2022 22:25:27
[DoS attack: ACK Scan] from source 13.35.7.2,port 80 Wednesday, Jun 15,2022 22:25:26
[DoS attack: ACK Scan] from source 13.35.7.2,port 443 Wednesday, Jun 15,2022 22:25:26
[DoS attack: ACK Scan] from source 13.35.7.40,port 443 Wednesday, Jun 15,2022 22:25:25
[DoS attack: ACK Scan] from source 13.35.7.2,port 443 Wednesday, Jun 15,2022 22:25:25
[DoS attack: ACK Scan] from source 13.35.7.2,port 80 Wednesday, Jun 15,2022 22:25:25
[DoS attack: ACK Scan] from source 13.35.7.40,port 443 Wednesday, Jun 15,2022 22:25:24
[DoS attack: ACK Scan] from source 211.21.118.138,port 443 Wednesday, Jun 15,2022 22:25:22
[DoS attack: ACK Scan] from source 34.213.154.34,port 443 Wednesday, Jun 15,2022 22:25:19
[DoS attack: ACK Scan] from source 35.155.91.63,port 443 Wednesday, Jun 15,2022 22:25:19
[DoS attack: ACK Scan] from source 34.213.154.34,port 443 Wednesday, Jun 15,2022 22:25:18
[DoS attack: ACK Scan] from source 35.155.91.63,port 443 Wednesday, Jun 15,2022 22:25:18
[DoS attack: ACK Scan] from source 34.213.154.34,port 443 Wednesday, Jun 15,2022 22:25:17
[DoS attack: ACK Scan] from source 35.155.91.63,port 443 Wednesday, Jun 15,2022 22:25:17
[DoS attack: ACK Scan] from source 142.251.43.10,port 443 Wednesday, Jun 15,2022 22:25:07
[DoS attack: ACK Scan] from source 20.115.3.214,port 443 Wednesday, Jun 15,2022 22:25:04
[DoS attack: ACK Scan] from source 20.115.3.214,port 443 Wednesday, Jun 15,2022 22:24:46
[DoS attack: ACK Scan] from source 20.198.162.76,port 443 Wednesday, Jun 15,2022 22:24:41
[DoS attack: ACK Scan] from source 20.198.162.78,port 443 Wednesday, Jun 15,2022 22:24:41
[DoS attack: ACK Scan] from source 17.57.145.27,port 5223 Wednesday, Jun 15,2022 22:24:41
[DoS attack: ACK Scan] from source 162.125.35.134,port 443 Wednesday, Jun 15,2022 22:24:40
[DoS attack: ACK Scan] from source 20.198.162.78,port 443 Wednesday, Jun 15,2022 22:24:40
[DoS attack: ACK Scan] from source 162.125.35.134,port 443 Wednesday, Jun 15,2022 22:24:39
[DoS attack: ACK Scan] from source 20.115.3.214,port 443 Wednesday, Jun 15,2022 22:24:38
[DoS attack: ACK Scan] from source 20.115.3.214,port 443 Wednesday, Jun 15,2022 22:24:37
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:22:45
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:22:12
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:21:59
[DoS attack: ACK Scan] from source 96.7.252.200,port 443 Wednesday, Jun 15,2022 22:21:46
[DoS attack: ACK Scan] from source 35.244.184.98,port 443 Wednesday, Jun 15,2022 22:16:36
[DoS attack: ACK Scan] from source 35.190.53.75,port 443 Wednesday, Jun 15,2022 22:16:36
[DoS attack: ACK Scan] from source 35.244.184.98,port 443 Wednesday, Jun 15,2022 22:16:35
[DoS attack: ACK Scan] from source 35.190.53.75,port 443 Wednesday, Jun 15,2022 22:16:35
[DoS attack: ACK Scan] from source 35.201.74.116,port 443 Wednesday, Jun 15,2022 22:16:34
[DoS attack: ACK Scan] from source 35.190.53.75,port 443 Wednesday, Jun 15,2022 22:16:34
[DoS attack: ACK Scan] from source 35.201.74.116,port 443 Wednesday, Jun 15,2022 22:16:33
[DoS attack: ACK Scan] from source 142.251.42.238,port 443 Wednesday, Jun 15,2022 22:14:36
[DoS attack: ACK Scan] from source 18.65.3.31,port 443 Wednesday, Jun 15,2022 22:14:35
[DoS attack: ACK Scan] from source 18.65.216.37,port 443 Wednesday, Jun 15,2022 22:14:34
[DoS attack: ACK Scan] from source 142.251.42.232,port 443 Wednesday, Jun 15,2022 22:14:34
[DoS attack: ACK Scan] from source 18.65.3.31,port 443 Wednesday, Jun 15,2022 22:14:34
[DoS attack: ACK Scan] from source 18.65.216.37,port 443 Wednesday, Jun 15,2022 22:14:33
[DoS attack: ACK Scan] from source 142.251.42.232,port 443 Wednesday, Jun 15,2022 22:14:33
[DoS attack: ACK Scan] from source 18.65.216.37,port 443 Wednesday, Jun 15,2022 22:14:32
[DoS attack: ACK Scan] from source 170.114.14.75,port 443 Wednesday, Jun 15,2022 22:13:56
[DoS attack: ACK Scan] from source 172.217.163.42,port 443 Wednesday, Jun 15,2022 22:13:38
[DoS attack: ACK Scan] from source 13.225.173.34,port 443 Wednesday, Jun 15,2022 22:13:37
[DoS attack: ACK Scan] from source 172.217.163.42,port 443 Wednesday, Jun 15,2022 22:13:37
[DoS attack: NetBiosReplyDrop] from source 192.168.1.10,port 137 Wednesday, Jun 15,2022 22:13:18
[DoS attack: NetBiosReplyDrop] from source 192.168.1.10,port 137 Wednesday, Jun 15,2022 22:13:08
[DoS attack: ACK Scan] from source 20.197.71.89,port 443 Wednesday, Jun 15,2022 22:13:07
[DoS attack: ACK Scan] from source 170.114.15.49,port 443 Wednesday, Jun 15,2022 22:13:05
[DoS attack: ACK Scan] from source 17.57.145.27,port 5223 Wednesday, Jun 15,2022 22:13:04
[DoS attack: ACK Scan] from source 8.252.189.122,port 443 Wednesday, Jun 15,2022 22:12:37
- jackylee0908Aspirant
Hi,
[DoS attack: ACK Scan] from source 8.252.189.122,port 443 Wednesday, Jun 15,2022 22:12:37- microchip8MasterMost are false positives. NETGEAR is known and famous about that. Disable DoS protection if your Internet drops
I found an interested thing:
The IP was reserved for my Synology NAS device but actually it was not powered up for long time, does that mean somebody want to connect my NAS?
