Mark-CS
Jan 23, 2023Aspirant
Many issues with Nighthawk RAX80
Hi, the Nighthawk RAX80 is my first Netgear router and unfortunately, I've got multiple problems with it. It feels like using a test device... 1. I turned the RAX80 off and on again and now, s...
Mark-CS
Thanks for your quick reply, but unfortunately, it's not helpful. The device I'm using only has "modem mode". So it's a modem not a router. I don't want to put the NETGEAR device in bad light, but with my last FRITZ!Box router it worked flawlessly. It's the WiFi of the RAX80 that's causing the problems (Ethernet works fine).
michaelkenward
Jan 23, 2023Guru - Experienced User
The description of that device is odd.
It calls itself a "Bridge Modem". But look closely and it has four ethernet ports, usually sign of router features. The data sheet description also talks of "pure bridged mode".
...with my last FRITZ!Box router it worked flawlessly.
Not the same device, and not anything that anyone can comment on given the lack of details.
Fine. You came her asking for thoughts, if you aren't interested in even investigating suggestions you are on your own.
- Mark-CSJan 23, 2023Aspirant
Sorry, I was very annoyed because I need this router (very expensive btw.) to work when I am in home office, and the answer you gave me was like "Did you forget to turn on the device?" for advanced users like me... đ Nevermind, and thanks again for trying to help. I guess the device is just broken and only NETGEAR could fix this. Maybe I'll wait for an update or sell it on eBay. I'll have to think about it.
- michaelkenwardJan 23, 2023Guru - Experienced User
Troubleshooting is a painstaking step by step process. It starts by ruling out the obvious issues before moving on to the next level..
I am surprised that someone with your experience is puzzled by this bit in our first message:
2. When I enable QoS my WiFi gets extremely slow. In addition, the device cannot connect to Netgear's servers to update the database.
QoS is well known to slow down routers because of the drain on processor power. It is also a dying technology designed for the DSL era. It is useless above about 200 Mbps.
When people turn up here with issues, "turn off QoS" is the first bit of advice.
As to this bit:
3. Sometimes, I have to disable WiFi on my devices and turn it back on to get full speed again. When I use LAN instead it's always fast. So it's only a WiFi issue.
That is one symptom of "Double NAT". It happens because, after you may the connection the devices "get confused".
Then again, you probably new all this already.
- Mark-CSJan 23, 2023AspirantSorry but this is out of context.
"It's the same with QoS. I disabled it and now it's back on again." <-- For this reason, I have mentioned it.
"That is one symptom of "Double NAT""
But I don't have a double NAT. Both devices are in the same network. But nevermind.
I'll keep this device and use it in AP mode with another router, because the range of this device is really good. Hopefully, they'll fix the issues some day.
