Mark-CS
Jan 23, 2023Aspirant
Many issues with Nighthawk RAX80
Hi, the Nighthawk RAX80 is my first Netgear router and unfortunately, I've got multiple problems with it. It feels like using a test device... 1. I turned the RAX80 off and on again and now, s...
michaelkenward
Jan 23, 2023Guru - Experienced User
Troubleshooting is a painstaking step by step process. It starts by ruling out the obvious issues before moving on to the next level..
I am surprised that someone with your experience is puzzled by this bit in our first message:
2. When I enable QoS my WiFi gets extremely slow. In addition, the device cannot connect to Netgear's servers to update the database.
QoS is well known to slow down routers because of the drain on processor power. It is also a dying technology designed for the DSL era. It is useless above about 200 Mbps.
When people turn up here with issues, "turn off QoS" is the first bit of advice.
As to this bit:
3. Sometimes, I have to disable WiFi on my devices and turn it back on to get full speed again. When I use LAN instead it's always fast. So it's only a WiFi issue.
That is one symptom of "Double NAT". It happens because, after you may the connection the devices "get confused".
Then again, you probably new all this already.
Mark-CS
Sorry but this is out of context.
"It's the same with QoS. I disabled it and now it's back on again." <-- For this reason, I have mentioned it.
"That is one symptom of "Double NAT""
But I don't have a double NAT. Both devices are in the same network. But nevermind.
I'll keep this device and use it in AP mode with another router, because the range of this device is really good. Hopefully, they'll fix the issues some day.
- michaelkenwardJan 23, 2023Guru - Experienced User
Mark-CS wrote:
But I don't have a double NAT. Both devices are in the same network. But nevermind.Being on "the same network", whatever that means, can be the problem.
Your reluctance to provide details is a big obstacle.
- Mark-CSJan 23, 2023AspirantI don't think it's an issue that both devices are in the same network. I connected LAN 1 of my modem to the RAX80 to access the user interface when I am not at home. If you can explain why this can be a problem, sure, I'll listen. Maybe you are right and I am missing something.
- Mark-CSJan 24, 2023Aspirant
It's weird, but the issues seem to have taken care of themselves. Hopefully, it stays that way. đ€
Side note: I didn't know about this hidden page: routerlogin.net/debug.htm
It seems to be possible to write logs to a USB storage device. Maybe it's useful to me in the future or it can help anyone else.
