Mark-CS
Jan 23, 2023Aspirant
Many issues with Nighthawk RAX80
Hi, the Nighthawk RAX80 is my first Netgear router and unfortunately, I've got multiple problems with it. It feels like using a test device... 1. I turned the RAX80 off and on again and now, s...
Mark-CS
Sorry but this is out of context.
"It's the same with QoS. I disabled it and now it's back on again." <-- For this reason, I have mentioned it.
"That is one symptom of "Double NAT""
But I don't have a double NAT. Both devices are in the same network. But nevermind.
I'll keep this device and use it in AP mode with another router, because the range of this device is really good. Hopefully, they'll fix the issues some day.
michaelkenward
Jan 23, 2023Guru - Experienced User
Being on "the same network", whatever that means, can be the problem.
Your reluctance to provide details is a big obstacle.
- Mark-CSJan 23, 2023AspirantI don't think it's an issue that both devices are in the same network. I connected LAN 1 of my modem to the RAX80 to access the user interface when I am not at home. If you can explain why this can be a problem, sure, I'll listen. Maybe you are right and I am missing something.
- Mark-CSJan 24, 2023Aspirant
It's weird, but the issues seem to have taken care of themselves. Hopefully, it stays that way. 🤞
Side note: I didn't know about this hidden page: routerlogin.net/debug.htm
It seems to be possible to write logs to a USB storage device. Maybe it's useful to me in the future or it can help anyone else. - michaelkenwardJan 24, 2023Guru - Experienced User
Telepathy. By visiting this place you focus the brainpower here to your problem by remote control.
