Scottwi
Oct 18, 2022Follower
Mesh Extenders Question
Hey guys,
I recently purchased a NetGear Nighthawk AX11000 RAX200 wifi router.
My question is. Can certain NetGear mesh router extenders act as wifi nodes to my nighthawk router? Or would they create a new network and I’m forced to buy an actual dedicated mesh system from NetGear?
1 Reply
Yes there is mesh extenders you can use. I usually only recommend using 1 mesh extender because nothing is controlling them.
If you're needing more than 1, I'd switch to a full mesh system like orbi because then there's a router controlling the system and you have better stability.
