Teddy123's avatar
Aug 23, 2020
Mesh network choice
I have 500meg (Virgin) coming into a four bedroom house, but hardly any internet in bedrooms and other parts of the ground floor. Virgin power adapters don't work and I'm considering a mesh system. I have (gaming) teenagers in separate rooms, so I need to pacify their current lack of service and 'dead zones' in other parts of the house.
So, can you please give me any advice on what I should purchase OR should I invest in an orbi wifi 6 Tri-band AC6000
There are probably 30 different devices (Including fourTVs needing 4K, eight mobiles, five laptops, printers and laptops).
My service provider is Virgin. I have a V6 box in the lounge and a second Tivo box in one of the bedrooms.
Sorry for the 'Noddy' questions, but:
- are there ethernet ports on the satellites
- would I need
a) a separate router (if so any sugestions)
b) need to switch off the wifi on the Virgin 6 box
c) just plug the Netgear cable to the V6 box.
Many thanks
Teddy 123
  • Hi Teddy,
    An Orbi WiFi 6 system would work great for you! The satellites and router do have ethernet ports. If you need any assistance setting up your newly purchased NETGEAR devices, you can always contact our support team using the link below.
    https://www.netgear.com/support/default.aspx
    Christian
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Teddy,
    Christian
