Firescue25
Jul 09, 2021Tutor
Mesh network with Nighthawk AC2600
I have a Nighthawk XR500 AC2600. I would like to find the best mesh setup and/or recommended setup for our 3,000 sq/ft home.
Jul 09, 2021Guru - Experienced User
Are you looking to add a mesh extender, switch over to a mesh system like Orbi, or just add a mesh system like orbi or the MK nighthawk to compliment your coverage?
Some details help..
- Firescue25Jul 09, 2021TutorI would like to add the nighthawk mesh satellites to my existing nighthawk gaming router to get great coverage of WiFi.
- plemansJul 09, 2021Guru - Experienced User
You can add mesh extenders. the MK nighthawk series, you'd add the router (in access point mode) to the XR500.
That'd allow you to keep the benefits of the XR system with the added coverage of the MK system.
Just make sure to use different wireless channels between the 2 systems to try and prevent wireless interference
- Firescue25Jul 09, 2021TutorJust to make sure I have this, I need to buy the pack with the mk router and satellite to make it work? I could just get the satellites and link them to the xr?
