jlggomez
Nov 08, 2020Follower
Mesh Satellite by ethernet cable?
Hi - I want to use the Netgear Nighthawk MK63 Mesh Router and Satellite system in my house. I will have the router and one satellite unit in my house. Then I want to connect the second satellite...
Nov 08, 2020Guru - Experienced User
Yes you can do it.
the only issue you might have is ethernet runs max out around that 300ft.
