Mdhedd94
Oct 20, 2021Follower
Mesh WiFi 6 Router(MR60)
I bought a Netgear Nighthawk mesh router today. Everything (phones, laptops, streaming TV) all connect, but not Skylight frame.
Oct 20, 2021Guru - Experienced User
1. what modem/gateway are you connected to?
2. what is a skylight frame? Did you contact them for help setting up?
3. did you use the same ssid as your old router so devices would just auto-connect? Or did you change ssid/password?
