EFG
May 21, 2020Follower
Mesh WiFi 6 System
My home and office are separated by 15 ft and my office is where the Business Internet provider installed the modem for internet service. From the modem, I connected a Netgear Nighthawk Tri Wi-Fi ro...
May 22, 2020Guru - Experienced User
you've probably got the new mesh system setup in router mode if you did it in the app. this would cause a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
try disconnecting the mesh system from the switch, hardwire a pc/laptop into it (or wireless) and switch it to access point mode. then reconnect it to the network.
this would leave your tri-band running router function and the mesh actingg as an access point.
