mark76w
Jul 29, 2022Guide
Mind blowing terrible support
I am able to replicate an issue on an R9000, replaced the hardware and same issue, Netgear wont support then they will then they wont. So I change to a RAX200 same issue straight out the box.
The support i have received to date over the last 7-8 weeks can only be described as disgusting/terrible/outrageous. Customer support will not talk with me and instead tell L2/L1 to keep giving me excuses. You want to replace the hardware and here we are 3 weeks later and Im still calling to ask what is happening.
There is no escalation path i can follow, the directors do not have messaging on Linkedin active (speaks volumes). A complaint means nothing to netgear.
What actual issue are you having (in detail)?
Its been my experience that if 2 different routers are having the same issue, it tends not to be the routers and tends to be something in the settings/setup.
- mark76wGuide
The technical details as is your assumption is not relevant, the issue has been accepted, the thread is about mind blowingly terrible support.
Regardless of config/setting/bug the support is terrible.
I'm not arguing that support kind of sucks. And the 90 days is really a buzz kill/pita.
Just didn't know if you'd fixed the issue or not because there wasn't many details.
support on the forums (from the public) tends to actually be quicker so was trying to help.
