mark76w
Jul 29, 2022Guide
Mind blowing terrible support
I am able to replicate an issue on an R9000, replaced the hardware and same issue, Netgear wont support then they will then they wont. So I change to a RAX200 same issue straight out the box. The su...
Aug 10, 2022Guru - Experienced User
The built in speedtest isn't accurate over 500mbps because it rarely chooses the best test server. I recommend testing on a pc/laptop hardwired into the router and using a browser. Then actually test on different servers in the browser as not all of them can saturate gigabit.
Topology
Aug 13, 2022Virtuoso
mark76w, with respect to the quality of NETGEAR technical support, my experience is that there is a difference between (a) spoken telephone support and (b) written “email” support. Support cases submitted in writing (with instructions that you want replies in writing) produce answers that are reasonably timely and helpful. However, speaking to a technical support representative on the telephone can be less satisfactory.
- mark76wAug 25, 2022Guide
To conclude my journey, I managed to guess the support managers email and got a L3 support person involved with a dev firmware issued that I tested (V1.0.10.140_1.0.79). This was ok and has been released.
Its been 2months of hell to get resolution on such a matter.
- plemansAug 25, 2022Guru - Experienced User
Sucks to take 2 months to get that and to have to guess a contact. Was hoping some of the other mods I tagged would be contacting you earlier to help.
- mark76wAug 26, 2022Guide
Got there in the end tho!
