greyk9
Apr 28, 2020Aspirant
missing 5ghz channels
RAX45 Nighthawk router, Any Idea why my setting only show 5ghz channels 36-64 and 100-112 as an option? Region is set to North America.
Apr 28, 2020Guru - Experienced User
Do you have its speed set for "up to 4800"mbps? That requires use of the DFS channels.
If you set it down to "up to 2400mbps", are you able to set it for the higher channels?
greyk9
Thanks for the fast response. Do you know of any issues running Channel 102 112 I have a lot of congestion on the lower channels
