PeteDog
Mar 06, 2022Star
Missing 5Ghz Channels
Like many others, I cannot figure out how to get the 40Mhz and 80Mhz 5Ghz channels to be available. My current settings are shown below including a screenshot showing that only the 20Mhz channels ar...
- Mar 06, 2022
For netgear routers, the channel width is determined by the “up to” speed.
Up to 4803Mbps = 160MHz channel width, and thus it will only list channels where it has access to a contiguous 160MHz in your region.Up to 2400Mbps= 80MHz channel width.
Up to 1200Mbps = 40MHz channel width.
Up to 600Mbps = 20MHz channel width.
As you pick wider channel width settings, certain channels will be omitted from the list.
The overall available channels is related to the regelortory region for the router.
For example, in the US, the following channels are available, and for the 802.11ax routers, they are not really doing 80+80 type setups to deal with gaps.
- Channel 36 5GHz Band
- Channel 40 5GHz Band
- Channel 44 5GHz Band
- Channel 48 5GHz Band
- Channel 52 5GHz Band, RADAR Sensitive
- Channel 56 5GHz Band, RADAR Sensitive
- Channel 60 5GHz Band, RADAR Sensitive
- Channel 64 5GHz Band, RADAR Sensitive
- Channel 100 5GHz Band, RADAR Sensitive, Passive
- Channel 104 5GHz Band, RADAR Sensitive, Passive
- Channel 108 5GHz Band, RADAR Sensitive, Passive
- Channel 112 5GHz Band, RADAR Sensitive, Passive
- Channel 116 5GHz Band, RADAR Sensitive, Passive
- Channel 120 5GHz Band, RADAR Sensitive, Passive
- Channel 124 5GHz Band, RADAR Sensitive, Passive
- Channel 128 5GHz Band, RADAR Sensitive, Passive
- Channel 132 5GHz Band, RADAR Sensitive, Passive
- Channel 136 5GHz Band, RADAR Sensitive, Passive
- Channel 140 5GHz Band, RADAR Sensitive, Passive
- Channel 144 5GHz Band, RADAR Sensitive, Passive
- Channel 149 5GHz Band
- Channel 153 5GHz Band
- Channel 157 5GHz Band
- Channel 161 5GHz Band
- Channel 165 5GHz Band
PeteDog
Mar 06, 2022Star
