PeteDog's avatar
Mar 06, 2022
Missing 5Ghz Channels
Like many others, I cannot figure out how to get the 40Mhz and 80Mhz 5Ghz channels to be available.  My current settings are shown below including a screenshot showing that only the 20Mhz channels ar...
  • Razor512's avatar
    Mar 06, 2022
    For netgear routers, the channel width is determined by the “up to” speed.
    Up to 4803Mbps = 160MHz channel width, and thus it will only list channels where it has access to a contiguous 160MHz in your region.
    Up to 2400Mbps= 80MHz channel width.
    Up to 1200Mbps = 40MHz channel width.
    Up to 600Mbps = 20MHz channel width.
    As you pick wider channel width settings, certain channels will be omitted from the list.
    The overall available channels is related to the regelortory region for the router.
    For example, in the US, the following channels are available, and for the 802.11ax routers, they are not really doing 80+80 type setups to deal with gaps.
    • Channel 36      5GHz Band
    • Channel 40      5GHz Band
    • Channel 44      5GHz Band
    • Channel 48      5GHz Band
    • Channel 52      5GHz Band, RADAR Sensitive
    • Channel 56      5GHz Band, RADAR Sensitive
    • Channel 60      5GHz Band, RADAR Sensitive
    • Channel 64      5GHz Band, RADAR Sensitive
    • Channel 100    5GHz Band, RADAR Sensitive, Passive
    • Channel 104    5GHz Band, RADAR Sensitive, Passive
    • Channel 108    5GHz Band, RADAR Sensitive, Passive
    • Channel 112    5GHz Band, RADAR Sensitive, Passive
    • Channel 116    5GHz Band, RADAR Sensitive, Passive
    • Channel 120    5GHz Band, RADAR Sensitive, Passive
    • Channel 124    5GHz Band, RADAR Sensitive, Passive
    • Channel 128    5GHz Band, RADAR Sensitive, Passive
    • Channel 132    5GHz Band, RADAR Sensitive, Passive
    • Channel 136    5GHz Band, RADAR Sensitive, Passive
    • Channel 140    5GHz Band, RADAR Sensitive, Passive
    • Channel 144    5GHz Band, RADAR Sensitive, Passive
    • Channel 149    5GHz Band
    • Channel 153    5GHz Band
    • Channel 157    5GHz Band
    • Channel 161    5GHz Band
    • Channel 165    5GHz Band
