LML20176
Sep 22, 2021Tutor
Missing tiles in app RAX200
I used to be able to set up the guest WiFi and there is no longer a tile. Any suggestions?
- Sep 22, 2021
Logging in through the browser and not using the app.
LML20176
Sep 22, 2021Tutor
Dumb question. What is GUI?
Sep 22, 2021Guru - Experienced User
- LML20176Sep 22, 2021TutorI did and was able to see the set up there. However, since it isn’t secure I prefer to not use the browser.
Just wonder why the app no longer has this function. Another issue I have is the app says the software version is the latest but when I go to the browser it says there is an update, but it times out when I try to update.- FURRYe38Sep 22, 2021Guru - Experienced User
IF there is an update, then you might manually update the FW using a wired PC and web browser. Factory reset and setup from scratch using the same wired PC and web browser. Once the router is setup and running. Try using the NH app.
Be sure to visit and post about any future RAX support needs in the RAX wifi6 series forum:
For any NH App support needs, Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general NH router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Good Luck.- LML20176Sep 22, 2021TutorThank you!
