BoutrosLowe
Apr 12, 2021Initiate
Mixing Tri Band Router and Dual Band Extender
I am looking to add a Wi Fi 6 extender to improve coverage at home but was not sure of what if any implications there are when the Router is tri-band AX11000 (and has one channel for backhaul) but EA...
- Apr 13, 2021
so single/dual band extenders drop speeds 50% because they have to use the same chip for going router---->extender and then extender---->device and the chip can't do both at once.
But the EAX80 is an AX6000 with the 5ghz being 4800mbps. So even if you cut its throughput in half its a 2400mbps (link speed) adapter. Which is still faster than the triband line.
But I haven't actually tested a EAX extender to compare.
I do have an EX8000 that works great but theoretically the EAX80 should be faster.
Apr 13, 2021Guru - Experienced User
