ron_pcolafl
Nov 14, 2020Aspirant
MK62 5ghz
OS Windows 10 Netgear MK62 Firmware version V1.0.6.102_2.0.45 Netgear modem CM1000 download speed up to 1.0ghz Just setup MK62 wifi6 mesh network router & satellite but I don't see ...
- Nov 15, 2020
ron_pcolafl wrote:
I have the router connected to the modem but when I try to connect to the network I don't have the option to
connect to _5ghz
networkname
networkname_5ghz
does that make more sense?
Not really.
I still have no idea what you mean by "I don't have the option to connect to _5ghz"
What do you expect to see?
Orbi wifi does not differentiate between 2.4 GHz and 5 MHz. It has a single SSID for both bands. (Look at the manual.) That is the whole point of the Mesh technology that you just installed.
If you can see the SSID, your wifi clients will pick the best one for them. Depending on the strength of the signal.
michaelkenward
Nov 15, 2020Guru - Experienced User
ron_pcolafl wrote:but I don't see the option to connect to either 2.4ghz or 5ghz?
Connect what to the wifi?
You have plugged the MR60, the MK62's router, into the CM7000?
ron_pcolafl
Nov 15, 2020Aspirant
This is the current configuration:
OS
Windows 10
Netgear MK62
I hope to upgrade to the CM7000 so I can increase my
download speed from 1.0ghz to 1.8ghz but first I need
to figure out why I'm not seeing the option to connect to
5ghz vs 2.4ghz.
thanks
