MarcinJ
Jun 16, 2021Follower
mk63 5Ghz connectivity issues
hey there, is there any way to force 5Ghz connection? I've recently purchased and connected Nighthawk MK63 and the current setup is that the router is connected to the internet provider (1gbit) at th...
Christian_R
Jun 18, 2021NETGEAR Employee Retired
Hello MarcinJ,
The Nighthawk Mesh system currently does not support the separation of the 2GHz and 5GHz band. I would recommend running through a factory reset as you mentioned.
Christian
