Intensified
Jul 14, 2021Aspirant
MK83 with RBK853
Is it possible to use an MK83 Satalite with my RBK853? I have a room wherre I am hoping to have a smaller AP than the Orbi satalite.
Jul 15, 2021Guru - Experienced User
No. they're not compatible
- IntensifiedJul 15, 2021Aspirant
Is there a compatibility matrix somewhere? I searched and couldn't find one.
- plemansJul 15, 2021Guru - Experienced User
I don't know of a compatibility matrix.
I know the Orbi 20/30/40/50 series will all work together.
the orbi 10 series only work with them selves.
I haven't used the MK series or the Orbi AX series to know theirs.
