Roberto_LDR
Jan 04, 2022Aspirant
Model CAX30 Device Manager
Hello, I have a Nighthawk AX6 AX2700 Modem Model CAX30 and i have the Nighthawk app that isnt properly working. The Device Manager tab isnt letting me remove my son's nintendo switch from the blocked...
Jan 05, 2022Guru - Experienced User
Try removing the app and re-installing.
Try app on a different device.
Netgear has set up a community forum specifically for the Nighthawk App product. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.
