Mikewin95
Jan 01, 2022Aspirant
Model R7000 AC1900 - Test Speed 97 Mbps for wired, vice 234 Mbps for Wireless, multiple computers
My Problem – My Router Speed Test from Spectrum and other places = 243 download and 8.3 upload with cable, 97 download and 11.5 upload with wireless This has been repeated with two other comput...
Jan 04, 2022Guru - Experienced User
And what speed did you get over 2.4ghz?
And over 5ghz?
Mikewin95
Jan 04, 2022Aspirant
I am getting 1/2 of my 200 Mbps for both 2.5 and 5
- michaelkenwardJan 05, 2022Guru - Experienced User
Those are reasonable speeds for some wifi devices, especially 2.4 GHz stuff.
The speed you get depends on the wifi clients. Do these devices go a lot faster when you try them with wifi somewhere else.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
By the way, the R7000 isn't one of the WiFi 6 devices covered in this section.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk WiFi Routers - plemansJan 05, 2022Guru - Experienced User
What device are you testing on to hit 100mbps over 2.4ghz?
2.4ghz is a slow network and sensitive to interference. And the R7000 is an 8 year old router.
its 2.4ghz was never that great.
How are you testing speeds? (device, app, etc)
