jcrafty's avatar
jcrafty
Initiate
Nov 15, 2020
Model RAX40 wifi router has to be restarted daily
I lose wifi daily at my business with this router.  My modem is perfectly fine and stable, but I lose wifi daily. Sometimes twice.    is this router defective?  How do I know if I have interference...
  • gsuburban's avatar
    Nov 15, 2020
    I'm going to take an uneducated guess that the router's WiFi "channel" is interfering with something else or something else not related such as a microwave, might be interfering with the WiFi.  I have an R6700v3 set for Access Point needs wired to another WiFi from the ISP which is the "modem" for the LAN. I read that the WiFi channels should be set on both devices to be different, not the same, to help with laptops and smart phones connecting to one WiFi device to another as they move farther away from one and closer to the other. That works but not perfectly. So, the R6700v3 was set to channel 1 for 2.4 ghz WiFi.  Worked just fine for a couple of months from being new but then I noticed the WiFi printer on the LAN would lose connection and that printer only has 2.4 ghz technology. Notice a smart phone would not connect to the 2.4 ghz channel but it would with the 5 ghz channel. The only solution of many I tried was to reboot the R6700v3 and then all WiFi devices on the 2.4 ghz band would reconnect but would then fail again after about 3 days or so. Same fix was rebooting the access point again and again after 3 or so days, disconnects would occur but only on the 2.4 ghz band.
    I had changed the 2.4 ghz band to a different channel so I moved it from channel 1 to I believe 6 and the problem went away. My guess there was some kind of interferance occuring. No issues since then and its been months with complete functioning.  The Netgear R6700v3 had the latest firmware at the time which would have been around September 2020 v1.0.4.102. While making those changes I did notice there was a channel setting "auto" however, because of the other modem/router on the LAN, I decided to set those channels to be fixed.
